Hey,
I am trying to understand a few things. I haven't really seen any place in the forums that would answer it, so I will just ask.
First off here is my proposed setup:
-Yamaha V663
- Emotiva XPA-5
-Ascend Sierra-1 LRC
-Ascend CBM-170SE x2.
-Epik Castle subwoofer
Now the questions:
I am trying to understand about the rules of adding an amp to my set-up. I have an interesting room layout. A 3000cu ft home theater room with a large opening into a 3000 cu ft dining room/ kitchen. The HT room isnt that large, in regards to length and width, but the 20 ft vaulted ceiling is is what is killin me.
Will a 5 channel amp work with a 7.1 receiver to power 5 speakers?
If I decide to only get a 2 channel amp for the LR Sierras, would this be a bad idea because the speakers may no longer be equalized with each other as they will be amplified differenty?
Also am I right in thinking that if I go with the XPA-5, I would hook up the receiver's pre-outs using RCAs to the amp, then from the amp to the speakers using speaker cable? Given that the V663 is a 7.1, it should have pre-outs for all channels, which would mean that if I decide to go to a full 7.1, and desire amplification, I would simply need to pick up an additional 2 channel amp, (XPA-2). I think I have the logic right, just want to make sure.
Especially interested in what you folks have to say regarding only amplifying certain channels in your multichannel setups.
For the record, I am 99% HT, and 1% music.
Thanks alot!
Matt
