99.99% silver wire at half price
dave1490
dave1490
hello i found a great price on fine silver wire it,s at present $23 per 50ft 24 gaw it,s jewery wire but still 99.99%fine.the site,s on the net called myrontoback.com.ph number 1-800-223-7550.i called and the responce i got was{oh your one of those sterio guy,s}guess im not the first lol.
tjlmbklr
I just connected new speakers. Does silver really help that much?
no. 5
no. 5
I can't imagien that it would; it's only a very little bit more conductive than copper.
if you wanted to try it $23 for 50 feet isn't to bad of a price, however, 24 gauge is VERY thin for speaker wire. better just to stick with 10 to 16 gauge copper wire.
Seth=L
Seth=L
Definitely fill us in on your experiance with it once you have it.
Most silver speaker wire is actually just silver coated copper. There is a slight difference to my ears, but not one to write home about - in other words, I wouldn't pay a premium for it. The interconnects I use for SACD/DVD-A are silver and they do have a slighlty different sound (highs are a little more pronounced) than when using copper ones from the same company, but again, it is a very minor difference.
24AWG is probably going to be too thin for almost every application, so you are going to need triple or quadruple runs, thus eliminating the cost savings.
no. 5
no. 5
so there can be a (very small) defrence, thanks for the info Garcia. :cool:
dave1490
dave1490
i made interconnect,s with this and it does bring out more detail in the tweets for bass thoughe id use 10gaw copper,copper gives more punch.
