$90 for a remote? Is it worth it?
krzywica
krzywica
brian32672
brian32672
The Kameleon 9960 is a decent remote, but you can get them new on eBay for about 35.00 - 40.00 The good thing with them, is that they are upgradeable they have a built in modem. I have also had a 3120 I think its called.
Also have had a Pronto TSU500 (you can get now for about 70-85.00 and this is computer customizable) , also had the TSU3000 MSRP 300.00 plus a 70.00 charger (you can find the remote & charger for 200.00)
By chance I just sold my TSU3000 (for a decent price), If you buy one of these, the charger is seperate - make sure you get it. However, this is much more customizable, and is more for a serious Home Theater. It can control everything these others can do, and much more. Including lighting, A/C's, Projectors, etc....
Now back to the 9960 that you are looking at. Are you good with a computer?
And if you are truly thinking of going about max 70-80.00? If so, then you may want something like the TSU500 or better. The 500 is a very easy remote to program, and all buttons are customizable.
However, if you do want the 9960, remember you can get it much cheaper than Best Buy. I had one, and it will control most of your components. TV, Stereo, DVD Player, Tape Deck, VCR, Satellite Dish, etc.. It is a learning remote, and learns quite easily. So you can learn all of your remotes into this, then put all the others into the drawer. The 9960 is a pretty sturdy remote. It also will eat batteries, so make sure you get some AA rechargeable batteries and a charger. With my 3120, it was much like this one. I had opened the remote up, and removed the motion sensor because it really ate batteries up fast. Anyhow, the 9960 fits in the hand well, it also is quite bright - So night viewing is easy for all buttons.
Have you ever worked with a Learning Universal remote?
Do you need advice?
krzywica
krzywica
Trust me you wont need help or advice if you go with the harmony. I've got a 688 and setup is so simple, they have every device you can imagine on their online database. All you do is enter the model numbers of your components, tell the site what activities you want to perform, and sync the remote with the included usb cable. And presto, one button setup for every activity. Oh yea and they can control ANYTHING that has an IR reciever on it.
BMXTRIX
BMXTRIX
genuinebigdog said:
http://www.bestbuy.com/site/olspage.jsp?id=1051826213181&type=product&skuId=5433783
you tell me because I dont know. Is this garantied to work with all of your products? It does look cool.
No remote is really guaranteed to work with everything you have except, perhaps, Crestron or AMX. That's several grand for a remote though.
I would look no further than the Logitech Harmony remotes or perhaps a Home Theater Master remote. The Harmony seems to continually get better reviews than the Home Theater Master products, and the Home Theater Master remotes continually get excellent reviews.
A hundred, or even a couple hundred bucks? So you can throw ALL your other remotes into a drawer and never need to pull them out again? So you can never have your wife say "But, how do I put on a DVD?"....
Yeah, definitely worth it.
