9.1 how to connect to the correct receiver outputs
toddbe
I have a 5.1 setup now and want to go preferably to 9.1. My existing and new speakers are all in ceiling.
I am leaning towards the Yamaha RX‑A3060 or the Pioneer Elite SC-LX801 or LX901. Dolby recommends for 9.1 a "wide speaker" setting. Neither receiver has a "wide speaker" output instead having a Presence or Front Height output.
How would I use the extra two speakers and where would I attach it at the receiver? Any preferences on which receiver?
Y
yepimonfire
If you want front wide you need a receiver that does either dts x or audyssey dsx, with DTS x it's still going to depend on whether or not the manufacturer allows you to assign a front wide configuration.
If all of your speakers are in ceiling then you're gonna have a problem. None of the sounds in the main bed channels are supposed to come from overhead. An atmos configuration with all speakers in ceiling would completely destroy the imaging of atmos.
Sent from my SM-G360T1 using Tapatalk
