8 Channel amp 1200watts @4ohms each
Seth=L
Seth=L
WOED!:eek:, I don't think my apartments will let me use that.:D
Wafflesomd
Wafflesomd
The input power makes no sense.
"IT REQUIRES A SINGLE PHASE 208V ELECTRICAL TIE-IN (2 HOTS, NEUTRAL AND GROUND"
What? 2 hots and single phase :confused:
All I can think of when I see that thing is HULK SMASH. :D That thing is a beast. Very 50s industrial looking too though....
jamie2112
I am thinking of buying this beast.I would never need another thats for sure....
Rickster71
Rickster71
Sounds like the person writing the ad hasn't a clue.:)
2
240jz
A electrician will understand. You would have to run a new feed from your electrical panel just for this MONSTER AMP! Hopefully, it doesn't draw more than your DRYER!!! WOW...
220VAC uses both hots that come into a building's single phase service. The neutral is used normally and the two hots are 180 degrees out of phase, so the difference is added.
If it's assumed to be 50% efficient (I'm sure it's more efficient than that), 9600W comes to 19,200W used and since P=I x E, 19,200=220x, or 87.28A so yes, it draws a lot more than a dryer.
I want to make my neighbor's lights to dim when I crank my system!
