Why not hook it up & see how the reception is,ive had as good of luck with using the lil cheap dipole antenna's as i have using powered antenna's,a thick gauge antenna does not always equal better reception.
From my experience with indoor antenna's if your going to get good reception out of a tuner or reciever your going to get the same reception weather using a dipole antenna as you will any other indoor antenna & unless you go the extreme route & use exterior antenna's.
