What do I need to know ? (ie. quality, brand, where to buy). TIA for any & all info/help. :)
J JCAz Enthusiast Apr 30, 2005 #1 What do I need to know ? (ie. quality, brand, where to buy). TIA for any & all info/help.
Dumar Audioholic Apr 30, 2005 #2 I use these binding posts: http://www.levitonvoicedata.com/catalog/BuildPage.aspx?BuildPageID=14 which snap into these multimedia inserts: http://www.levitonvoicedata.com/catalog/BuildPage.aspx?BuildPageID=33 The inserts mount to a standard electrical box, and the whole thing gets finished off with a decora wall plate. I like these because Leviton makes all kinds of different connectors that fit the inserts so you can mix and match. Check it out: http://www.levitonvoicedata.com/catalog/CatalogGroup.aspx?CatalogSection=B All this stuff is available at Home Depot, and the quality is pretty good. Hope that helps.
Duffinator Audioholic Field Marshall Apr 30, 2005 #4 Scroll down to to the bottom of this link and you will see a plate with 8 binging posts instead of 6. Hometech has very fast service. http://www.hometech.com/techwire/audioconn.html
