Powertrader said:
What do you think of the ceiling mount with the di-pole/bi-poles?
Sounds like too much speaker for too small of room. (too many speakers)
From everything that I have read/been told, it is more important to "do" a 5.1 system well than it is to "do" a 7.1 system poorly. And 7.1 really needs some space to the rear of your seating location to spread the sound, rather than pin pointing the sound (hence the desire for dipole/bipole speakers).
Another way to look at the problem.... the side speakers and rear speakers will be concentrated (rear and side walls). This means the ambience sounds will be concentrated rather than spread over a wide area.
Is mounting the speakers on the ceiling possible? Sure, if you can find some way to mount those heavy guys on the ceiling.
