N
Nab89
I want to install a 7.1 surround sound system in my room for my PC. I know this isn't for a home theater but it's the same concept. The position of the PC has made it difficult to decide where to put the speakers and I would like your advice.
The speaker system I'm thinking of getting is Creative's Gigaworks S750. Note I only want the speakers for gaming.
Here is a plan of the room with a suggestion for the speaker layout:
The PC is under the bed on a desk. Here the back speakers are located above the bed and wardrobe. The left speaker is on the windowsill, and the right mounted on the wall, below the bed. The left front speaker is in the corner and the right directly across the room on the right.
Would this layout be suitable? Are there any suggestions.
I have also made an alternative layout:
Here the back speakers are below the bed just to the left and right behind the PC. The left and right speakers haven't changed position. The front speakers are just to the left and right of the PC in front.
Any comments about this layout?
Although I would preffer a 7.1 speaker system, perhaps you think 5.1 would be better? any layout suggestions?
Any help will be much appreciated.
