7.1 Setup Help...Side and Rear speaker Help
BigWilly1231
Looking to Pick up a Mordaunt Short Avant setup and was wondering, if for the 7.1 setup I should go with bookselves on the sides or the surround speakers on the sides. Same for the back.
In other words should I get 4 of the Mordaunt Short Avant 903S, or should I change it up a bit.
Thanks
Snap
Snap
I am not sure about those types of speakers. We also do not know what your room looks like. So with out the room info, it is kind of hard to determine what kind of speakers you will need.
Personal Pref. for 7.1
I like Bi-Pole/Di-Pole for the Side Surrounds, and Bookself speakers for the back. But that is just my personal pref.
