You both should be fine.
All that number is saying is that for the same volume level you'll be drawing a little more power than an 8 ohm speaker would.
In either case, common sense and your ears will tell you if you're getting too close to the danger limit. If that doesn't work then then your receivers protection circuit will kick in, although I doubt this will ever happen.
Speakers can handle more power than you can imagine in a real world situation. Now, if you connect them to a sine wave generator and a mo fo amp and push 'em to their limits you may have problems but, in the real world, they aren't drawing as much power as you think. Most normal listening only uses a few wattts at most. It's the momentary peaks that put the demands on and, in HT, a LOT of them are in the subwoofer's domain.
One good rule to keep in mind in this hobby is that if it starts to sound bad, something is wrong and you should turn it down immediately.
