To clarify the 8 ohm spec. is not a physical characteristic of the receiver. It is a safe rating. What it says is that the amplifers produce their rated power output into that impedance. Virtually all of them will drive a load 1/2 that impedance but they aren't rated for it out of conservatism and, probably, legal advice. The manufacturer is saying that, if you use 8 ohm speakers, the receiver will behave as specified. As others have said, using 6 ohm speakers won't be an issue.
