When selecting the Multi Ch Input (6 channel analog in) on the receiver, it sends a signal to turn off the external amp via the 12v trigger. When I select the Multi Channel input again to turn it off, it turns the external amp back on.
Have I missed something in the setup, or is this likely a defect in the receiver?
If I use the receiver without the external amp, the Multi Channel Inputer works with the internal amp as expected.
All suggestions are greatly appreciated.
