my room is about 7.5m x 4.5m with a ceiling about 12ft. high my t.v. stands on a 3ft. base in one end with the screen about a meter from the wall, my bed (6ft. wide)centered on the other end is directly against the wall, plus, to the left and behind my bed are windows that start at 3ft. and end 8ft. high. I am convinced in using one bipole on each side of my bed. How far away from the rear wall should the bipoles be? and how high?, should I also use a bipole for the rear center? and how high should the rear center be?. What do I do? I need your help masters!
