.....two speakers wired in series emit more presence, as they have become twice-efficient....cross-wiring at one end gives the same result to a single speaker....you 7.1 guys cross-wire your rears and see what you think....bear in mind you've got your subs to keep you warm....go for life, presence, transparency, and above all, "clean"......
.....there could be no doubt the Earthquake three-channel amp would be good....signal noise of 112, 111, and 111 at three different measurings.....seperation of 95 db....tuff....somebody get that TDeluce to post where he got it for around $1300....Gentlemen, you'd be through with amping for the front three for life....the Crown K2 is awfully good also....the K-Series have a crossover-cut at the top and bottom....the amp is STRONG right up to the limits at both ends....and with my speakers and subs, delivers pristinely clear "everything".....
