Hello. I have abandoned my Yamaha 663 and am going back to my Lexicon DC-1 prepro. The only thing I will miss with the yammie is it's 12v trigger. My Parasound Amp and NHT sub amp were plugged into a
Niles AC-3 triggered power strip.
The Lexicon has a PWR CTL port. This is a 5 pin DIN connctor. The OM says, "pins 1 and 2 are ground, pin 3 is high when unit is on low in standby or off. High is indicated by either +5VDC or +12VDC, selectable via an internal jumper. Pin 5 can be enabled (high) or disabled (low) for specific input selections in the Setup Menu."
I bought a radio shack 5 pin DIN cable which plugs into the Lexicon's PWR CTL port. I cut the other end off and exposed the wires inside, the bare wire copper shielding, and red, yellow, black, and white wires. The Niles triggered outlet has a control in with two jacks, one + and one -. I tried some basic combos hooked up to the Niles and the Lexi to no avail. (ie red + black - etc)
Any thoughts from the talking heads here? Will this even work? Thank you in advance.
(i know this should go in cables and interconnects but that is deadsville, man)
