7.1 in and of itself is a myth. There are no recordings currently available that have 7 discrete recorded channels plus the sub. There are also no systems that could decode seven channels if they were there. Please note that top notch systems like the upper line (ie $ 5K) Denons have 9 channels available, but they have no decoding developed to run them.
You can find a few DVD's that really are mixed in 6.1, but every system out there claiming to be 7.1 just uses a processing algorithm to split the sixth channel in two. It is moderately effective, at best, and solely depends on how well the algorithm's guess matches the sound track mix on the DVD as to how good the additional channels will sound.
Somewhere down the line, somebody will have a home version of the "real" 7.1 or 8.1 or 9.1 sounds systems in use at the theaters, but there's nothing out there right now.
For the size room you have, I don't think you would get enough spacing between the side and rear speakers to actually get much out of the extra two speakers. You might get better results using "prescence" speakers, a Yamaha 7.1 technology, that works with front speakers instead of rears, and doesn't need any extra space.
I think Ray from RLAhometheater.com is a retailer for RBH speakers.
