Hello
I have a 2 x Genelec 8260A speakers which are being fed a digital signal through my computer audio setup.
It is as pure as it can get.
I am looking for a DSP solution or a Processor which takes the digital signal and processes to create a 180 degree sound or a 5.1 surround sound with my same set of Genelec audio speakers.
I am trying to get a more surround effect rather than a boring stereo 2D effect.
Any processors or DSP that I can output DSP'd digital signal that I feed into my Genelec's
Jazz, Pop and Rock are my genre's/.
Several points. Your speakers are near field studio monitors, so probably do not have a great depth of field.
If you had a 5.1 set up for most of what you listen to the Dolby algorithms will not work. Some good minimally miked jazz 2 channel recordings they might work for.
For pop and rock it will not work. These are awash is time and phase shifts plus artificial echo and other horrid effects from a multitude of plug ins. Engineering standards for this genre of music have never been good and are now rock bottom.
If you liked classical music then for a lot of recordings a good 5.1 and 7.1 effect can be created.
What you are after is not going to happen. Stay with two channel.
