If you aren't going to use a sub then you would need to set at least the front speakers to large so that the lfe channel willl be directed to be output to your main speakers, effectively turning off bass management in most scenraio. Many receivers won't allow you to set sub to no / mains to small anyway, so you might not even have that option, which is a way of dummy proofing the setup.
