Hi there,
If an amp is spec'd to drive 4 ohms, then I would suspect that it will be able to handle that load. Many good amps can drive the 4 ohm load; some cannot. Many, many receivers will not like a 4 ohm load. Check the documentation before buying, just to be sure.
The problem is that with a decreased impedance (4 ohms vs 8 ohms), the speaker demands twice the power from the amplifier. If the amplifier cannot provide it, problems can ensue. I've run many, many receivers with a 4 ohm load when they don't necessarily want it. At lower volumes, I've never had a problem. At higher volumes, the unit may get hot, run out of gas early, and go into protect mode. Worst case, it will fail prematurely, but I think that unlikely with a well-protected and engineered amp or receiver.
Find a nice amp, and you'll be fine.
