Been emailing with Nathan for the last week (he's been amazing to talk to, super fast to respond and very patient!) and a lot of things happened!
I decided to order a master slave pair of 2 18.0SEs (since these go behind the transparent wall) followed by another additional master slave pair if I like the first two (for total 4).
I was talking to Nathan about getting the ultimate sound quality and he suggested using the higher quality motor from the 21.0L sub.
Let's call these "Uber 18.0SE" from now on
The resulting sub would be able to do the following:
1. Perform as good as normal 18.0 above 60hz
2. Have about 2db less between 30-60hz compared to 18.0
3. Have actaully 2-3db more under 30hz compared to 18.0
4. Have a lot less distortion thought the entire range (has more linear travel as well) - much more musical
I feel like this is a great tradeoff since mostly you end up equing down in the 30-60 range due to room modes and under 30 is where the sub really can use the extra output.
Thanks to Nathan for being so flexible and striving to help his customers get the best most fitting product for them.
The sub with this new motor is considerably more expensive (and heavier) but it's worth it for me since I'm trying to get the best SQ possible out of my subs.
What has driven me to this decision is Nathans incredible customer service and also measurments on the databass as well as some things I was able to find on JL Audio Fathom 113v2 and 112 measurements shared in this thread.
Funk Audio 18.0 has the following advantages:
1. Overall more output - about 2-3db over JL Audio and with the new motor probably up to 6-7db more under 30hz than JL Audio. So 2 Funks should play like 4 JL Audio's in terms of output.
2. Funk plays much better above 100hz with a very nice low THD and flat response where as JL Audio decays and distortion rises after 80hz. This means I can cross higher and easier getting the best dynamics and SQ out of a system (Most people seem to agree that with a great sub going with higher crossover as high as 100 or 120 leads to the better sounding overall system, especially at refernece levels).
3. Funk plays much lower since there's no high pass filter so I can hopefully hit the single digits with meaningful response in my sealed room.
4. Funk has slightly better group delay, especially in lower frequencies
5. Funk seems to have a much better impulse response, the one that settles after about 5ms, where as JL Audio seems to still have "left over" vibrations for another 50ms.
6. Funk has a much much lower distortion level at all frequencies (especially below 30 and above 80) at much, much higher volume levels.
7. 4 "Uber 18.0SE's" still cost much less than 4 JL Audio Fathoms 113v2's.
I will try to get the JL Audio dealer to agree to bring the sub to do a head to head comparison so that I could write a proper review of those subs head to head in my room.
What more, I started talking to Nathan about his speakers and got really interested in those.
Luckily there was the 8.2 pair available so I will be lucky to be able to audition it with the first 2 subs when they arrive!
I will be able to compare the speakers to B&W CT 8.2 and 802 D3's with Classe. Given that 8.2p's will cost 30% (accounting for amplification) this will be very interesting.
I have a feeling that I will prefer Funks sound just knowing how crazy passionate and cutting edge Nathans products are but we will see! Can't get better than listening to both side by side.
I will post my impressions and reviews once these things will get here! CANT WAIT!
