You probably know I am not a fan of using the so called external power amps with the upper midrange AVR typically rated at least 100 WPC, 20-20,000 Hz at THD+N less than 0.1%. I do often suggest the use of real power amps rated at least 200 WPC 8 ohms and 300 WPC 4 ohms 20-20,000 Hz THD+N <0.05%. Such power amps would guarantee 3 dB more SPL under most use conditions, and their 4 ohm ratings are believable, and should be able to drive 4 ohm nominal, with dips to as low as 2.5 ohms as long as the users don't need to push their amps too close to their clipping point.
The Denon AVR-A1H, is probably the only AVR, since the time of those AVR-5803, 5805, 5308, Yamaha RX-Z9, RX-Z11, Onkyo TX-SR805, SR875, 876, NR5008, Integra DTR-8.8 that can be paired with 4 ohm nominal full range speakers configured in 2.1, even up to 5.1.
That being said, if the user (we don't know in this case as we don't know the OP's listening habits, distance and his speaker specs) has the need to push his fairly expensive A1H close to its clipping point, for another $1,000 to 1,500 he may still benefit from using a 2 or 3 channel power amp in terms of clean power during the peaks and at the minimum, potentially longevity as well.
So, like you, and ADTG, I am not one who would waste time and money on external amps when there is no need, no case for them. The Op may or may not benefit from further spending on electronics, but if there is, he would have plenty of good choices, as the A1H has excellent preamp/dac quality, and high enough voltage for just about any external power amps including those low cost Hypex, Purifi based modules that tend to have about 3 dB lower gain than the AVR internal amps.
