35 feet - Belden 1694A Component Video Cables (3 wire) with 12 feet of Braided Cable Jacket. Sells for well over $130 at BJC, yours for a song!
Here's the magic adv stuff--
Canare's RCAP series RCA plugs represent the best in broadcast-quality terminations for component video cables. The Canare plug body is all metal, coupled with a silicone strain relief boot, and provides superb electrical contact, shielding and impedance performance. Unlike traditional RCA plugs, which were designed originally for analog unbalanced audio, the Canare plugs were designed with video in mind. To minimize impedance mismatch resulting from the RCA connector's unfortunate dimensions, Canare has carried the cable's coaxial geometry as close to the end of the RCA plug as the design will allow, and has preserved the cable's critical dimensions--the relationship between the center conductor and the shield--as much as possible, so that the inevitable impedance "bump" at the RCA interface is kept to a minimum. For that reason, these plugs aren't one-size-fits-all; for every component video cable we build, there is a specific model of Canare RCA which fits that particular component video cable. The contact surfaces are gold-plated--but where most connectors use no other means besides gold plating to ensure good contact, Canare RCAPs have a unique "internal pressure contact finger" system, partially visible in the photo at right. Nine gold-plated spring surfaces squeeze the jack from all sides--firmly, but without excessive force--for a perfect, mechanically solid and electrically sound contact every time. A simple side-by-side comparison of these plugs with those found on the mass-market cable brands leaves no doubt as to which is the superior connector.
12 ft Braided Cable Jacket.
