http://www.buy.com/retail/product.asp?sku=203533407&adid=17281&dcaid=17281
Specs:
Screen Size 32-inch (16:9)
Pixel pitch 0.018 in x 0.018 in
Display Color 16.7M(up to panel specs)
Max. Resolution 1366 x 768(up to panel specs)
Contrast Ratio 1200:1 (up to panel specs)
Brightness 500 cd/m2 (up to panel specs)
Viewing Angle Horizontal:+85/-85, Vertical:+85/-85 (up to panel specs)
Response Time Tr:15ms / Tf:10ms (up to panel specs)
Synchronization Range Horizontal:30~80KHz, Vertical:50~75Hz
Front Controls Power, Source, Menu, Channel Up, Channel Down,
Volume Up, Volume Down, Enter
PC OSD Control Auto adjust, Brightness, Contrast, Volume, Phase, Clock, H-Position, * V-Position, Sharpness, Color
Temperature, Source select, Sleep timer, OSD Time Out
PC Input Terminal D-SUB 15 Pins / DVI
PC Audio in PC Audio-in Jack × 1.
Earphone Earphone Jack × 1
Speaker 10W × 2
Plug & Play VESA DDC 1/2B
Power Input AC100~240V, 50~60Hz
Power Consumption TBD
Power Saving VESA DDC 1/2B, Power Consumption<=10W
VESA Compliant
TV Tuner NTSC-M/M System
TV Support Display SDTV: 480i, EDTV: 480p, HDTV: 720p/1080i
TV Decipher Function V-Chip, Closed Caption
TV Audio System MTS, SRS Focus
Picture In Picture PIP: YES
Inputs/outputs:
DVI in
Component in x 2
Audio in x 2
S-video in x 1
AV in x 2
D-SUB 15 pin in
cable in
PC audio in
Subwoofer out
AV out
Included:
32" LCD TV
Power cord
Remote controller
Batteries(AAA/UM-4)
User manual
Warranty card
Physical Dimensions
W/ Stand: 1067 mm (W) x 567mm (H) x136 mm (D)
W/o Stand: 1067 (W) x 512 mm (H) x 136 mm (D)
Weight Gross: 30.3 Net: 25.6Kg
