G
glenn9812
I have 3 JL audio 12w6 duel 6 ohm subs. Hadthese when i was in high school. Used them for about a year and have been sitting in my room since. Was thinking about using these subs in a newbox fora home audio build. but mabye just 2 of them. they arerated for 300 wattsrms each. Would this be a good idea to use them? There just sitting there. Theses are the 1st versions thatcame out (originals).
WmAx
WmAx
The W6 version 1 is still a high quality driver, though it has been substantially exceeded in performance by the likes of the W6v2, Infinity Kappa Perfects, etc..
If you use all 3 of these, you will have a very good amount of available SPL with relatively low distortion. However, each sub needs about 5 net cubic feet. Since the power handling and excursion is very limited on these subs, you can get away with 2 x 4" cylinder vents on each sub, each vent being about 25" long. Most modern subs require more complex/very long slot ports to keep air speed in the port low enough to prevent substantial port compression.
Can you deal with 3 cabinets in your A/V room? Each being about 6 cubic feet (gross)? If so, go for it. You should provide about 200-250 watts each of these drivers.
-Chris
lsiberian
lsiberian
Most certainly.
I would use 2 as stands for high quality bookshelves like the Modded Behringer 2030p
and then place the 3rd in the rear of the room.
I don't see any problem using them. You can probably use 300w bash amps for these since they are only 300w subs. PE sells them for 125 each. But you will still need a subsonic filter. I'm sure Chris can recommend the frequency.
I would just buy a pair of EP1500s and cross them with a DCX 2496.
