G
gcmarshall
is anyone aware of other makes/models of 3-channel amps that put out 200-250 wpc, other than what i have listed below?
Adcom 5503
monster 3250
levinson 433 (way too expensive anyway)
anthem has some, but that appear to be rated at 180 wpc
others?
tdeluce
Adcom 5503
monster 3250
others?
Earthquake Sound Cinenova Grande 3 ( 300 watts into 8 ohms ; 600 watts
into 4 ohms ) : http://store.yahoo.com/federalstereo/earsouncin3.html
smokey007
i have two anthem mca 30 amps. they are rated at 180 at 8ohms. but at 4 they are above 200 per channel. they drive my axiom speakers very easy at very high levels with no clipping at all.
The13thGryphon
The13thGryphon
The current Bryston 3-channel amp is the 3B SST, which is rated at 300 w/channel into 8 ohms, and 500 w/channel into 4 ohms.
Aragon used to make one called the 8008x3, so you might be able to find that on the used market.
Odyssey Audio makes the HT3, which is only 150 w/channel... but it sounds more powerful than its rating.
Krell makes the KAV-3250, rated at 250 w/channel into 8 ohms... though it too would obviously be a bit on the expensive side.
Happy hunting!
Adcom 5503
monster 3250
others?
For $540 total you can buy 3 Behringer A500, bridged mode with 360 watts into 8 ohms and do it all 3 ch driven. :D
Can any of the suggested amps do this?
G
gcmarshall
boston acoustics' recommended amp power for my VR3 mains is a max of 250 watts per channel. i think it's not wise to violate this recommendation very much, if at all. i have to assume boston acoustics recommends a 250 watt max amp power rating for a very good reason and i have to assume boston acoustics knows what they're talking about; they built the speaker.
Rob Babcock
Rob Babcock
Moderator
Acurus (a sister company to Aragon) made some. There's a 200 x 3 Acurus on Agon right now for around $600. I don't know the guy selling but he has very good feedback.
Lots of companies make amps in 2/3/4 & 5 channel versions. Some are pretty spendy. What's your budget?
talannar
Rotel used to make one. RB-993, 200 x 3. It's a little older, but can be found for under $500 on Audiogon.
E
eirepaul
AudioGon is a great place to get power amps. There isn't a whole lot that can go wrong with these units - they are usually pretty sturdy.
If you feel that you would turn the volume up so much that the amp will deliver more than 250 watts of RMS power for any length of time, don't buy those amps. But then, just be careful not to clip the amp you do get.
You may want to call them and ask about what dynamic power their speakers will take. Believe me, if you set your volume to a reasonable level, you will not get dynamic power that will damage your speakers.
I
indcrimdefense
cary audio design cinema 3, 3x200; krell kav-3250, 3x250. I demoed a cary cinema 5 (5x200) several times earlier this year, which is same design & chassis as the cinema 3, and i own a krell kav-2250. never had opportunity to hear the cary audio & krell at the same time at home, but would highly recommend either. i didn't buy the cinema 5 b/c i had a ground loop hum with it that i could never get rid of, and i lucked a fantastic sale on a kav-2250, unfortunately all of them are gone or i would have bought another kav-2250 or 3250 if they would have had either left.
the cary sounded the best when used w/ cary cinema 6 pre-pro, excellant for music & movies. my krell is currently used w/ a demo anthem avm-20 and is also excellant for music & movies. i would highly recommend either amp, particularly if paired with a quality stereo or surround pre-amp/processor.
G
gcmarshall
indcrimdefense,
thanks for the input. the krell KAV-3250 fits the bill, except for its very high price. plus, i would only be using my yamaha RX-V2500 as the pre-amp and wonder if that yamaha as a preamp would be a "weak link" and somehow limit the potential performance of the krell. in any case, i may decide spending that kind of money on a krell amp is too much. there is a stand-alone magnolia opening nearby soon, so i may check them out when they open.
you're in indianapolis.....do you know the wank & o'brien radio show? i know o'brien....i'm related to him.
jcPanny
jcPanny
Amp options.
I wouldn't rule out 3 of the Outlaw monoblocks as an option. Also keep in mind that adding 2 channel amp for the mains would allow the reciever to deliver more power to the center and surround channels. This would probably work well unless all of your speakers are 4 ohms and inefficient.
Also, your yamaha is highly rated for use as a pre-pro with audioholics measurements to back it up.
I
indcrimdefense
yes i'm familiar with wank & o'brien, but rarely listen to radio. i have zero experience w/ yamaha, aside from a recent 20 min listening session of a 2600 at a dealer. what i can tell you from adding a seperate amp to my denon 2805receiver is that it made a difference, but the difference it made depended on which amp i used. i was unable to achieve the sound quality i was looking for using the 2805 as a pre/pro, but i will say that adding a 2 channel amp and running the surrounds from the receiver was a very cost efficient compromise, and am improvement over the receiver alone. i have klipsch rf7 fronts & rf5 rears, which are reported to be very efficient speakers. however, the more quality power i provide them, particulary the fronts, the better they sound. it's not simply a matter of sheer volume, as i have noticed since purchasing the krell that i actually listen at reduced levels than i did before. the quality of the music is better (cleaner, crisper, more detailed, lacks the mushed together or compressed soud), and has substantially more body at a much lower volume level than using the 2805 alone. as for improved bass response, there is really no comparison. i would recommend demoing some amps & using them w/ your receiver first. if you dont hear a difference or dont like the difference, dont buy the amp. audioholics recommends sing your receiver as a pre/pro, so the place to start would be demoing some amps, and seeing how they sound to you. have fun
K
kcd911
B&k 3*200
I picked up a used B&K 3*200 wpc from audiogon, works great, no problems.
KCD911
