3.5mm Splitter Question?
JBrown1597
I have a desktop PC with speakers on the table, and a new pair of headphones. The front audio jack on my computer sounds horrible, so I need to use the back audio jack for two different outputs.
Suggestions on a good 3.5mm splitter? 2 female to 1 male.
Preferrably one of premium quality as retaining all sound quality is a must.
Length does not matter, I only need an extra foot or so.
Thank you so much!
rojo
rojo
Thank you so much!
I really dig KabelDirekt. https://www.amazon.com/dp/B00GN76HAG/
But honestly, there's probably nothing that can be improved upon Monoprice's less expensive offering. https://www.amazon.com/dp/B00DIGCY0W/
If your integrated audio is really that crappy, it might not be a bad idea to consider a cheap DAC. https://www.amazon.com/dp/B00FEDHHKE/ looks interesting.
