$3 10' Banana to Speakon cables from Musicians Friend
sawzalot
sawzalot
Does anyone on what gauge the wire is I looked all over and couldn't find any specs.would this be good for the infinity perfect kappa subs from my 2500,dcx setup?
MidnightSensi
MidnightSensi
I have some getting here on Tuesday, I'll let you know what gauge they are. usually speakon terminated cable is pretty large gauge, like 12 or 14, but I'll let you know for sure when I get them.
The 2500 has speakon outputs and then you could use the banana's into the Kappa's enclosure. From the dcx to the 2500 I'd use a pair of XLR cables which are standard for line level.
