Knowing that so many of you have been waiting with bated breath to find out how my HT redo went, here's an update.
I auditioned a number of speakers at a BB Magnolia Home Theater, most of which I didn't particularly like, but I did like the Def Tech SM55 (also a Magnepan floor-stander, but that's a different story). Wasn't too happy with the price for LCR on the Dec Techs, so continued to research other small speakers. A couple of months ago I came across a guy selling a trio of the SM55's and bought all three.
While that was going on I changed my mind about keeping the Sony receiver and bought a Yamaha RX-V673 when the price dropped on those. My main reason for this was to be able to route all my sources through the receiver, instead of having the HDMI sources going direct to the TV. Doing it that way I was getting lip-sync issues that couldn't be fixed using my Vizio's adjustment. In addition, it was confusing for my wife to sometimes select the source on the TV and sometimes on the receiver. When I bought the Sony it was supposed to be an inexpensive stop-gap measure while I got the system sorted out, so after twelve years, it seemed time.
The Yamaha and the Def Techs arrived around the same day. I had also ordered 50 feet of 12-gauge zip from Monoprice and 6 pairs of Deadlock banana plugs from Sewell Direct. Service from both places was outstanding and the products were fine. One of the plugs was defective--Sewell sent me another pair immediately. The plus made wiring up everything much easier.
To get the receiver online I ran an ethernet cable from the Apple Airport Express I've been using to source streaming audio via TOSlink to the system and removed the TOSlink. As soon as I turned on the receiver it automatically updated itself, which took about 30 minutes via wi-fi.
Getting the Def Techs installed took a bit, since I had to run wires invisibly through the cabinet and bore out some holes, but it came out looking great. I'm still experimenting with having them tilt down.
Having lived with it for a a few months, I'm very happy with the outcome. The receiver works very well. The "scenes" buttons make source selection really easy. I really like the ability to have it turn on muted. It seems to have more than enough power for our listening area at the levels we listen to it, which are lower now than they used to be many years ago. While I don't believe Def Tech's frequency-response numbers for a minute, the sound has surprising heft and impact, especially considering I don't yet have a sub. On Dolby-encoded source material the stereo spread is excellent and the center-channel not only keeps voices on the screen, but has virtually eliminated our need to keep the captioning on. The system also sounds quite good playing streaming audio.
I still have work to do on it--haven't run any sweeps or applied any EQ and need to get a sub. The sub is another piece that well-meaning experts here will tell me is impossible, since the small theater area is just a piece of a 14,000 cubic-foot room, which despite the size, limits me to about a 15" x 15" floor space for the sub. When we tried a soundbar, the tiny sub provided an acceptable (to us) low end. I'm going to try an SVS-SB12NSD and see how that goes.
The other part of the project happened down at the other end of the room, where I have a NAD C375BEE driving pair of Thiel CS3's aimed across the width of the room. I installed the Allison CD8's facing the length of the room and wired it all up with another spool of Monoprice 12-gauge and Sewell Deadbolts. The original wire I used was from HD and it had all turned green over the years, so I rewired the whole system, which took 49 feet of the spool. The Allisons sound much better standing upright against a wall than they did on their sides on the top of the cabinet. I can now have great sound no matter which part of the room I happen to be in.
By the time I add a sub I'll have about $1,500 into this, but the result has exceeded my starting expectations by quite a bit, so I'm glad I did it.
Here's what it looks like now:
Danny W.
