2nd crossover setting
peppino
These are the specs. on my surrounds -System Type: 2 Way - 4 Driver Bipolar Surround Speakers
Midrange: Dual 4 inch Polymer Treated with Butyl Rubber Surrounds
Tweeter: Dual 1" Neodymium Balanced Dome Ferrofluid Cooled
Power Handling: 20 - 100 Watts
Frequency Response: 130 - 20K Hz
Sensitivity: 88dB
Crossover Frequency: 4000Hz Phase Coherent -PCB Mounted Circuitry
Impedance: 8 Ohms What should i set the crossover hz on my amp to?
johsti
Wow, do they really only go down to 130Hz? what kind of speakers are they? I would do some frequency sweeps with avia and see where they start to drop off. If they do indeed only go down to around 130Hz, than you should set your crossover at 150Hz on your receiver.
Sensitivity: 88dB
What options do you have? I would set it to 120Hz.
