25ft Digital Connection
anamorphic96
anamorphic96
I want to run a 25ft digital cable and want to know which would be the best for this length. Async USB, optical, or coax. I can place the DAC at my main stereo or computer.
Thanks for any input. I have done some internet searching but get mixed information. From what I can tell coax maybe the best bet but thought I would check with my fellow Audioholics.
agarwalro
agarwalro
I believe 15ft is the limit of USB transfer without an active solution.
Sound quality wise Optical and Coax will be equal. The Optical signal transfer will be 100% free from EM noise, though it is almost never an issue. That said, for Coax, you do want one with good shielding. Just pick whichever cable is cheapest.
anamorphic96
anamorphic96
Thanks for the input. Probably going with Blue Jeans coax to be safe.
If coax is the initial source output, use that and terminate it normally. If you have hum in the system from a ground loop, use a coax to optical converter- it's impossible to have a ground loop when using optical and it works great.
anamorphic96
anamorphic96
I have read optical can have issues with higher resolution 24/96/192 files over longer distances so I decided to try coax with good shielding. It seemed to be the most common. If I have issues I can try optical.
BoredSysAdmin
BoredSysAdmin
*cough*boolshit *cough *
Somehow fiber cable could be used for 100gbit connection, but not to carry 24/192 signal which needs a whooping 9mbps :)
Don't be silly. Optical cable would be best, coax 2nd best.
anamorphic96
anamorphic96
Thanks. I used a ten foot optical cable for several years with no issue. I might just give optical a try since shielding is a non issue.
Over long distance, but 25' isn't terribly long. one of the worst things to do to an optical link is bending it tightly. The outside of the fiber isn't absolutely smooth and light has a habit where the angle of incidence equals the angle of reflection, so it's best to keep it as straight as possible with no kinks, no wrapping it like an extension cord, no tight coils or tight bends.
RG59 or RG6 works fine for this, too- solid copper center conductor is easiest to work with.
