MakeYouTap
On my cinenova grande amp I have a dial that turns from 20hz to 20khz. Were should I put this? Also it has hi, bypass and low pass. Were should I have these set? I'm running my deff tech bp7006 with no sub.
fuzz092888
fuzz092888
Set everything to bypass and ignore the dial
MakeYouTap
OK does it not matter were its at? I've moved it back and forth but could not here a difference.
Jcharger13
On bypass the dial does nothing. It's bypassing the internal crossover.
Its a built in active crossover.
Here is how it works with out getting into to much detail (slopes, etc)
If set to low pass it will pass below the frequency the dial is set at and cut away high frequencies. Exact opposite for high pass. So if you are powering a sub you cut the high frequencies out (low pass) or if running bookshelf's you don't want sub bass playing out of them so you run a high pass. Your deftecs are full range so you don't need the crossover.
MakeYouTap
Very good explanation. Thank you I understand now.
