2 wire SW to single jack on receiver
Jeff56
Just bought a new receiver, but it only has one RCA type jack out for the SW. My SW has a pos and neg wire connection.
How do I make the connection?
Jeff56
I'm learning...
So it seems that my old sub is passive and needed power from the amp. My new receiver doesn't power the sub, so I have 2 choices - 1) buy a subwoofer amp, or 2) buy a new subwoofer.
I'm giving this set of speakers to my son so I don't want to spend a bunch of $ on this. I've seen sub amps for about $60 online.
The sub is 8 ohm with 100W max power. There is a 70W amp that provides 45W at 8 ohms for $62, and a 100W amp that provides 75W at 8 ohms for $102. Will the 70W amp be strong enough to give decent bass sound, or do I need the 100W amp?
markw
With a sub, you want as much power as you can get.
Adam
Adam
Welcome to the forum!
In terms of buying an amp or getting a new sub, what sub do you currently own? Were you happy with the sub's performance when it was in your old system? It sounds like it was part of speaker system or home-theater-in-a-box set up, and if so, you can just let us know what system you have.
As for powering your current sub, you could use the receiver that you had (if you haven't given it away, yet) or any other older receiver that has RCA inputs. That's likely a temporary fix, but you can use it to try out the sub with your new set up. You would run the subwoofer output from your new receiver to an RCA y-splitter (if required), then to one of the audio inputs on the back of the old receiver, then connect the old sub to the old receiver using the speaker-level connections like you did before. The volume control on the old receiver would act just like the gain control on a subwoofer amp. I did something similar a few years back. Don't be surprised if you need to turn the volume control on the old receiver up quite high.
