Hello all,
I am a brand new member on Audioholics. I've been watching Gene and Hugo's video's for a few months now, and stumbled upon the video about multisubs and minidsp. It got me wondering if i should go the same route.
About a year ago i bought a BK XXLS400. Although i'm pretty pleased with its performance (decent bass and no angry neighbours), i keep wondering if i made the right choice. Back then i contacted the guys from BK and they actually advised me to get a monolith or monolith+ (due to roomsize). Not sure why i went against their advise, probably because the huge sizedifference of the sub and my fear that the neighbours would get more bass-output than i did
When setting up, i did do a subwoofer-crawl, but couldn't really hear any difference, so i put the sub closest to the primary listeningspot, which was also furthest away of the wall seperating my home to that of my neighbours. I do think that the short distance to the subwoofer, makes it perform better than it should when it was placed at the "ideal position" (next to the front speakers).
After watching the video about minidsp and the fact that i can get a second hand BK Monolith for a reasonable price, it got me wondering if i could increase the performance of my setup and what would be the best way to do it.
Should i buy the Monolith, and a minidsp and go for a multi-sub solution.
Or should i buy an equalizer (like an anti-mode 8033) and try to get the max performance out of the xxls400?
I know that i should first measure it's current performance, so i bought a minidsp Umik-1, which will arrive in a week or so. But is it possible to give some expectations without measurements?
And my most important question (which i'm still not sure about). Is it expected that the neighbours will experience higher output also, when i'm optimizing my bass? Although they are an older couple, and probably have limited hearing-capabilities
they won't be living there forever.
Oh, this is the (far from ideal) room-layout. It's a livingroom, so the placement possibilities are very limited.
Option A (sub could also be placed in between the lamp and the closet):
Option B:
