2 receivers to 1 set of speakers
U
Unregistered
Guest
Whats the best way? Can i just run the speaker wires from each receiver directly in to each speaker or should i get a speaker wire a/b switch and use it in reverse? Of course only 1 receiver will be used (on) at a time. Thanks
Unregistered said:
Can anyone tell me a safe way?
Why are you doing this setup, just curious.
But, if you must, I would suggest positive swithces so there is no chance of both being connected at the same time. Perhpas each speakers with a double pole double throw switch?
U
Unregistered
Guest
I have a surround sound receiver for my home theater, a stereo receiver for my music, and a set of tower speakers i would like to use with both. I dont see whats so unusual about it. I thought someone might know of a switching device i could buy?
JoeE SP9
JoeE SP9
Pardt Express has a switcher. Catalog #300-604 DLS 6 Pair, 2 Source Speaker switch. Be forewarned it is $100+. That said; I am as curious as mytrycrafts. I am puzzled as to why one receiver for music and one for HT? Huh? :cool:
U
Unregistered
Guest
The reason why is i bought a Yamaha HT in a box system for my TV to watch dvd movies. In the meantime my stereo receiver die'd and i hooked up my turntable and tape deck and they sounded terrible on it! It sounds great with digital sources but terrible with analog. Therefore i bought a new Onkyo receiver for my turntable. I have a pair of tower speakers i want to share with the HT as front speakers, and for my stereo when i want to listen to my old LP's. The Yamaha HT only has 30 Watts per ch. each front, center and rear. I probably should have started out with a good A/V DTS dolby 5.1 receiver and built a complete system around that for my analog and digital sources but my situation and finances said otherwise.
There may be a fancy one somewhere, but a place like Home Depot will have that double pole-double throw switch I mentioned above. The center poles to the speaker and the other two to each amp.
I guess you may be in the minority who want to do this setup swap. But, nothing wrong and you can make it go.
If you don't care how the switch looks behind your speaker, the one I mentioned should be about $5 each, one for each speaker, or less; nothing fancy.
