With the Blu-Ray, are you wanting to do the newer audio formats also via HDMI?
Just to recap, you're looking for:
1) 3 (or more) HDMI in
2) 4-ohm capable
3) Zone 2 @ 8 ohm (I believe most Zone 2's will only be rated for 8 ohm speakers, anyways)
4) price range ???
-pat
Probably no on the BD audio.. just movies..
Price range is around the $1400 mark.
I looked at dakmart after reading some other threads here, but I am hesitant with B stock considering that this is for my parents. I don't want to have a problem a year from now and then tell them "you bought a refurb unit, what did you expect?" I am actually making all the choices on this system, and would much rather spend a few more dollars and get full manufacturer warranty and preferably a local retailer so that if there is a problem I can take the unit to them and say "replace it".
I have local sources for Yamaha and Denon, but not Marantz. (actually there is a Marantz dealer but its more of a garage type business..)
I sold and installed Marantz and M&K for quite a few years, and back then I liked the product combination, but then I left the industry and heard that Marantz was using garbage amplifier sections for a while. I currently have the M&K's running off an SR5000 and I get chills every time I go to their place and fire up the system.. I have the same receiver myself with some middle of the road Polk fronts and NHT rears and it is good enough for me these days, but damn I love those M&Ks. They never use it though, so I am putting in a theater in the room they do use. I need ease of use over everything, which is why I want something newer that has hdmi switching and upscaling (for the xbox360 - yes they like to play golf on it).
The room is also a nightmare for sound stage, so the audysee should be helpful there.. It doesn't have to be perfect, but I want it to be impressive to them and their friends..
I am going to go see what kind of deal the local denon dealer will give me on the 3808.. if he can come down a couple hundred from full retail I will purchase it. Then all I need is to pick out some on-wall surrounds and order up the in-wall wiring and plates and I can get started.. I can't wait to start punching holes in their walls.
Thanks for the advice. I have ebayed enough to know what to expect, but I was looking for someone to confirm that despite their claims at being an authorized dealer, it is likely that if a warranty situation came up I would be left holding the ball.
