2 pairs of speakers
soulmusic
I have a NAD C355 BEE amp and I would like to run (2) sets of outdoor speakers (4 total) - both sets will have 8 ohms impedence. The C355 spec reads;
* 2 x 80W Continuous Power into 8 ohms
* 140W, 220W, 270W IHF Dynamic power into 8, 4 and 2 ohms, respectively.s
Will my amp handle the (2) sets of speakers or am I risking a problem with my amp?
Thanks for your help,
Derek
Seth=L
Seth=L
Derek
What are the speakers?
soulmusic
I'm going to be using TIC Corp 8 ohms rock and patio speakers. Haven't purchased yet.
XEagleDriver
XEagleDriver
Should be OK
Derek
Derek,
After reviewing the C355BEE's manual online, you should be OK with either of the following set ups:
1) Connect two pairs of 8 ohm speakers in a parallel electrical connection to the Speaker A terminals,
OR
2) Connect one pair of 8 Ohm speakers to the Speaker A terminals, and the second pair of 8 Ohm speakers to the Speaker B terminals. Then press in both the "Speakers A and B buttons" on the amp's front panel.
However, pick one option or the other and do NOT do both of the above together, that would create too low of a load and damage the amp! :(
Furthermore, leave the Soft Clipping Switch on the back of the amp in "ON" to protect your speakers/amp when listening at higher volumes. (Manual p.8)
Lastly, if the "Protection LED" turns RED during use, then either the TIC speakers advertised 8 Ohm rating is optimistic (unlikely) or there is a short somewhere in the installation.
Cheers,
XEagleDriver
