2 channel help for...
Martiad3
...a Bose wave radio.
Wow that hurt to type. My father is looking for a 2 channel (maybe 2.1) setup to hook to his wave radio. If you didn't know, the radio has a LR stereo out on the back, I'm just unsure how to utilize it. Only ideas I've had are some computer speakers.
So here's the request: I need some reccomendations for a pair of speakers to hook up to the wave radio. They will be hooking up directly to the Red/White stereo output. If it's possible, a system with a sub would be nice as well.
Thanks for the help and, please, no useless cracking on Bose.
deftech
Computer or ipod speakers would work. I have klipsch pro media pc speakers. I like their sound.
jaxvon
jaxvon
What is dad willing to spend?
Martiad3
Preferably around $200, no more than $500 (i.e. the less expensive the better).
Requirements changed.
Seth=L
Seth=L
Not better for sound, only wallets.:D
You could even get a receiver and a pair of decent speakers with that budget.
Is Dad a new electronics guy or will he consider used stuff?
Martiad3
Heh, you posted as I edited.
New stuff
If I tell him, he'll consider used things (as long as they're in good condition though).
Seth=L
Seth=L
Good cosmetics on used products becomes less common. Maybe stick to new stuff. I made a post on your new thread with recommendation.:D
N
Nick250
My comments from your other thread:
3. Move the Wave Radio elsewhere, connect the CD Changer to a stereo receiver and from there to a ~$200 pair of speakers (X-LS also).
Choice three by a mile if it were me. Get the best speakers you can find and for a receiver, something around the $150 like the Onkyo linked below. It's really all about getting the best speakers you can find, the receiver is a very small part of the sound quality equation.
Nick
http://www.crutchfield.com/S-in02yXlJjcL/cgi-bin/prodview.asp?i=580TX8222
__________________
