2-channel equalizers?
  • Thread starter Rock&Roll Ninja
  • Start date
Rock&Roll Ninja
Rock&Roll Ninja
I'm running a NAD c370 integrated amp, and will soon be upgrading my loudspeakers. I will be adding a powered subwoofer into the mix, and was wondering, which EQ would be best for adjusting both the subwoofer and the 2 mains, and it has to be added in-line, because the c370 doesn't have a "sub out" connection.
Budget: under $500
N
nm2285
Can't help too much with the EQs, however, I also use the NAD c370. I run my sub through the Pre-out 2 jacks and it works just fine. May want to give that a try.
Rock&Roll Ninja
Rock&Roll Ninja
Can you recommend a good 2-channel EQ for the subwoofer?
WmAx
WmAx
Budget: under $500
Behringer DCX2496
Behringer DEQ2496
Both will not add noise or distortions(when configured properly!) no matter the application(hi-fi stereo, headphones, etc.). Both are very precise instruments. The DCX is suggested over the DEQ, as the DCX has further functionality over just equalization if you want to explore other things in the future. The DCX also has a computer user GUI(if you want to connect to a computer) if you are so inclined.
-Chris
