Even if you go with a big old vintage Marantz or something like that, you will pay more than $300.
You had better keep your eyes glued to eBay and hope you can snap a steal.
The other thing is, you could use very efficient horn loaded speakers, then you would not need much power.
What are the speakers you hope to use, anyway?
