Zone 2 - page 30 explained
Bascially you have to set up Zone 2 from your menu under "
2. Manual Setup"
The options allow you some volume levels and protection on Zone 2.
The white and red RCA connectors can be connecte to wiring. There are adapters example:
http://www.antonline.com/p_AH41-NX_277983.htm
First black box 1 Lch is the Left Channel Level ( white RCA connector). Sound is measure in dB levels; each 3dB is a doubling in sound level
Send black box 2 Rch is the right channel elvle ( red RCA connector).
I would start at 0 db; if the sound is too loud on Zone 2 when you Zone 1 is what you like then increase by 3 dB. Vic Versa if the sound on zone 2 is too low when zone 1 is at a compfot level then increase in 3dB increments until the sound in zone 2 is what you desire.
black box 3 Volume limit; If the speakers in zone 2 are smaller than your main zone 1 speakers you can set a volume limit and protect the zone 2 speakers in case zone 1 is turned up loud. If zone2 are substantially smaller you can set intiailly at -10dB
Black box 4 power on level; when you first turn on zone 2 do you want a preset level or remember the last level? I would either set "last" or "-10dB" to start with. If you set -10 db and can't hear then increase in incrtements of 10 dB.
black box 5 Mute level; when you turn on Mute "zone 2" how much sound do you still want to receive. Most like you want 'full" setting. If you mute a zone you want no sound.
Amp assign has to be set to zone2 to use zone 2 independently.
Sorry if this isn't clear enough, best I can do, I tried to help
