I recently moved into a house and I'm looking to install a Home Theater System in the Living Room. It is already pre-wired for 5 speakers, unfortunately, the locations are 12.5 feet high. From my research, it is recommended that they are at approximately ear level. I have access to the attic, so I can run new wires or move them around. I will be mainly using this setup for TV/Sports/Movies/Gaming. Occassional music, but that's not my main concern.
I have a 55" Samsung that I've mounted to the wall using the slim profile mounts (similar to hanging a picture). I may upgrade in the future to a large 4K TV, but I'm not in a rush for that.
Room Size: 15'6" front to back x 19'5" width x 20' height. Hardwood floors w/ an 8 x 10 area rug.
Receiver: I was looking to spend around $500, I'm ok with a refurbished unit depending on the vendor where I can return it if it arrives DOA (amazon, etc.). I was looking at the Sony STRDN 1060. I like some of the features such as 4K, Bluetooth, # of HDMI inputs, etc. It doesn't have ATMOS or Audyssey, is it necessary?
Speakers: I'm looking for In-Wall Speakers. I don't want it to look cluttered with floor or bookshelf, I understand the sound quality won't be as great as those, but I think the overall sound will be better than my TV. I'm not really sure what to go with. I've seen the following online: Polk, Klipsch, Boston Acoustics, Bose. I think I've narrowed it down to one of the two, but I'm not sure the difference between manufacturer.
- Klipsch:
- L&R: R-3650
- Center: R-5502
- Boston Acoustics:
- L&R: VSI-585
- Center: VSI-555
Rears:
What would you recommend for the rears, also do they NEED to be at the sides or can they be behind you? I have two pillars that separate the living room from the kitchen and was thinking about adding them inside there.
Sub: I haven't researched this yet, so any recommendations would be great.
Wiring: What size gauge would you recommend?
Thanks for your time, any comment would be appreciated.
Brown = TV console
Gray = Couch
Green = Rug
Purple = Windows (on right)
Corner = Fireplace (top right)
Blue = Hallway (top left)
Blue Boxes = Pillars behind couch
1 Box = 1 sq. foot
