Hello everyone,
If I could get some assistance with purchasing my 1st amp, I'd greatly appreciate it.
I am running a 5.1.4 system.
Receiver: Anthem Mrx1120
L/R: Definitive Technology BP9040 with Atmos enabled A90 attached
Center: Definitive Technology CS9080
Surround: Definitive Technology Pro monitor 800
Height: SVS Prime Elevation
I have narrowed my search down to two amps maybe 3 as a possible to drive my front 3. The receiver can drive the rest.
Prime choice: Emotiva XPA 3 275w x 3 The most powerful of the 3 @1199
2nd choice Monolith: 7 200w x 7 slightly less power than Emotiva but for only $400 more get 4 extra channels which a 7 ch in Emotiva prebuilt or sending the XPA 3 back in to add channels at a later time will cost more than the Monolith.
Last Outlaw 5000: 120w x 5 Least power of the 3 & most budget friendly @ 599 but not sure if would be able to tell the diffrence in power between the 3.
I am more concerned with power, performance & sound quality. I'm not in need of balanced inputs & from reviews it seems all amps had good build quality & nothing significant to report as a con. If anyone has had a comparison between these any info is appreciated. Also if the info given could be in layman's terms, I'm not a tech or an engineer I'm a noob lol.
Thanks in advance
