19" Rack mount Blue-ray player
walter duque
walter duque
Is there any company that makes a 19" rack mount Blu-ray Player?
Seth=L
Seth=L
Onkyo's Blu-ray player might be capable of being set up this way, the similarly styled pre/pro 885 is rack mountable with the installation kit. I would contact Onkyo regarding this, also the Integra devision.
bandphan
bandphan
Also check tascam and yamaha pro models. Also check the chassis screws to see if the ears can be added to others.
Seth=L
Seth=L
Naturally Sony, Panasonic, LG, Samsung, and many others don't have the cabinet design to support ears. I didn't know Tascam had a Blu-ray player.
bandphan
bandphan
Its was their DVD player recorder not blu ray, sorry..
middle atlantic makes rack mount shelves for standard gear..
BMXTRIX
BMXTRIX
Why would you buy one with rack ears? Why not just get a 19" rack shelf from Middle Atlantic that fits the product properly.
Trashcam makes some of the worst products I have EVER seen and they are incredibly sophmoric with their RS-232 protocols and customization capabilities. Easily the least impressive products I have ever touched next to the Marantz 'pro' products that are out there.
Just pick up a new Panasonic, order a custom fit rack shelf, call it done.
It's about $120 or so for any piece of gear you want a rack shelf custom made for.
walter duque
walter duque
I am not looking to rack mount it. I have a Salamander rack but all my equipment is rack mountable so my Sony Blu-Ray looks kind of out of place. Even my processor is rack mountable. I think the Oppo might fit in nicely. Thanks for the advise.
MidnightSensi
MidnightSensi
He is saying you can buy a shelf from middle atlantic and they will cut a faceplate for you, most stuff they already have the data for so you just order it. If they don't have what you want to cut, they will send you a sheet to fill out. It makes your equipment look flush even if it doesn't have rack ears.
