In my opinion, good quality copper wire is all you need, so don't focus on any particular brand.
avaserfi is right. Banana plugs, spades, or bare wire is based on your preference. I use banana plugs because it makes it a lot easier for me to connect and disconnect the speaker wires from my receiver (as I'm reaching around the back of my entertainment center). Plugs and spades add another resistance to the electrical circuit, but as long as you get decent connectors and make good metal-to-metal contact between the wire and the connectors, then you'll be fine.
