sab30
Im just getting a little worried that everyone talks about 14 gauge, I was told by a Hi Fo speciality store that 16 gauge would be fine. I do plan on running a 7.1 through it with some good wattage and high quality bookshelfs..do I need to start tearing down walls and re-wiring?
Will I even notice the difference between 16 and 14.
Thanks,
SAB
ruadmaa
16 gauge is more than adequate for most home applications unless you have an extremely long run. As for how much amplifier wattage you are going to use on these lines it really makes no difference. I have yet to see someone heat up a speaker wire with too many audio watts!!!
MBauer
16 AWG - works for me
The run distance is the key thing to consider. 16 will be fine, especially if it already there, unless you have runs longer than 50 feet. In an ideal state, bare wall, new construction, running 14 AWG or even 12 AWG is a good idea, the wire and connector costs are close and the lower AWG number could be a good investment, same as extra outlets, Cat 6, etc. But, if the 16 is there I don't think you will notice a real world difference, You may, if the type of listening is especially critical, if not I wouldn't worry. I use 16 for my family room HT setup and it works great.
Installing wall connectors is a good thing to do (I had good luck with Leviton Snap Locks) and it allows me to change things around pretty easily when and if I need to
sab30
Wheww..okay that soothes the nerves..the runs are very short in a dedicated HT room. The longest run is 16-20 feet of wire the rest are probably more like 10-15.
SAB
Shinerman
Shinerman
Your fine with 16ga. for those distances.
Shinerman
