on high level cable there are 3 coloured wire 2 go to + 0f speaker the other goes to - of speaker ...the quads speaker output terminal are so that the negative is connected to earth. that is why you cant use power amps that are bridged .. eg musical fidelity high powered amps,, the earth would s/c the amps and damage them.. the rel stampead as failed therefore replaced with rel t7i. .connected the same way as old one it worked fine for 15 years . ,with the new sub ,same connections s before the mains power neon goes off and speaker doesn't operate . disconnect sub power light on on 57s ,music plays .the mains of the quads goes to a step up transformer the neon light is connected to the mid voltage point of the primary. the secondary has a diode/capacitor ladder network that increases voltage across the plates to 5000 volts cheers and thanks
