15" eclipse aluminum(6ohm) & adcom 555 bridged
TuroK27
hi,
ok, so i've got plans for a new sub setup(title).
i was using a streetwire ZN 2.0(purple) caraudio rca for my old powered 12"(dahlquist) sub. well tonight i went out & bought an acoustic research "master series" subwoofer cable for my new sub setup.
will i be better off sticking to the "AR" cable vs. the streetwire caraudio rca?
the "AR" cable is twice as thick & looks more upscale :rolleyes:.
please give me your opinion as i can always take back new cables for a refund....
thanks,
turok
Privateer
Cables do not make a difference. Just make sure you use the right cable for the job, if you need a long run you can use a shielded cable or a XLR balanced design.
brendy
You will not hear a difference.Save your money & return the AR cable.
