If you're not using the Zone 2 inputs, all you need to do is assign the triggered output to one of them. It will do nothing to the main zone operation, in any way. Then, you can use one of these (or something like it):
So I assume I can configure that 12V trigger in my setup menu on my 805?
Have you looked at my power strip, it has a 12V input trigger on it, am I missing something?? Does the power strip not work off my 12V trigger to turn on my switched outlets? Or does the power strip send a 12V trigger out to turn on something else....There is not really any detail about this in the Manual. Maybe I need to contact Monster.....
Thanks
Jeff
