shokhead
shokhead
It seems most DVD players are set to this as mine is so would it be better to set the front mains to large for SACD playback?
bobbydigital
bobbydigital
yes set them to large. this is what I do and I like it much more then when set to small. You should also set the speaker delays in the DVD/SACD player and the speaker levels in there. Many people have found they need to increase sub volume in the Dvd/sacd player set-up menu for Sacd/dvd-a music
Buckle-meister
shokhead said:
...would it be better to set the front mains to large for SACD playback?
No Shokhead! :eek: Don't do it! :eek: Don't set them to Large! :eek:
Your signature says that you have B&W 601 surrounds, B&W 603 front towers, and an SVS 20-39 cylinder sub. The frequency responses for your speakers are 60Hz to 22kHz, 44Hz to 22kHz and 20Hz to 100kHz respectively. By setting your fronts to Large, you are in effect saying that you have full-range speakers when in fact you do not (full-range speakers strictly cover a minimum of 20Hz to 20kHz).
You definitely do want to take advantage of your sub's ability to go all the way down to 20Hz by setting all speakers to Small. The only issue left to resolve is then the value to be assigned to the crossover between speakers and sub.
If you look at the frequency response of all your speakers apart from the sub, you'll see that the highest of any minimum value is 60Hz, therefore, this is the setting you should set the crossover to. You wouldn't set it less than this because even though your 603's can cleanly deliver sound under 60Hz, your 601's can't, so the 601's are the limiting speakers in your setup.
In addition, the crossover setting of 120Hz you currently have is way too high. In general, people can tell where sounds of frequency greater than about 80Hz are coming from, so if you kept the crossover setting at 120Hz, you'd be hearing sound that was meant (for example) to sound in front of you wherever you currently have your sub placed, i.e. potentially behind you! By lowering the crossover setting down to 60Hz, you practically guarantee that this won't occur, yet you'll be getting a full-range signal (covering all speakers) at the same time.
Perfect. :)
BobbyDigital! Where's my whisky?! :eek:
shokhead
shokhead
Yes i know all that. I was talking about my DVD player where it is set at 120Hz. I do have my Denon at 60 and all to small. I was just wondering since you cant change yhe xover in the player,would it be of ant benifit to set the 603's to large for SACD playback in the Sony.
